will an eclipse 2.0L bolt to a mighty max tranny?
standardbyker88 avatar
standardbyker88
i wonder, because the gears are turnin in my brain to build a mighty max with an eclipse turbo engine.
ok, so will the engine bolt up to the manual tranny from the mighty max? what about any of the other 2WD RWD trannys dodge or mitsubishi makes? thanks guys...
Low_SST avatar
Low_SST
why not build one with a starion turbo motor. its a 2.6l thats based on the 2.0/2.6l block thats already in the ram50/ mighty max. this turbo motor is an easy junkyard find and it came in 2 cars. starion and conquest tsi.
jmurphy avatar
jmurphy
Depends on what year Max and Motor that you have. I have a 91 2.4 and yes it will bolt. If you go to Mightyd50.com look around in the forums and all of your questions will be answered. there are a few with the 2.0 turbos on that site.
solows10 avatar
solows10
not sure on years but a guy on one of the Teckademics MISCHIEF did that and it was bad a**
