Foreign Cars (honda, etc) \  3 Wheel Problems, HELP!!!!!!!!!!!
views 114
replies 7
baggedLVintegra   +1y
So I just bought 4 more valves in order to three wheel my teg, like most cylinders mine have the bottom port to suck the wheel up, well ive been through all the fittings and for some reason once it sucks up the wheel, after a few seconds it leaks down and I dont know y, its leaking from around the cylinder and im wondering if my seals are bad in my cylinders, or even if thats possible? or if its fixable? any help would be greatly appreciated, heres a vid of what it does
frmlayin   +1y
If you can tell that it's leaking then yes you are going to have to replace the cylinders, however what kind of cylinders do you have because some can not be rebuilt. You may have to replace the whole cylinder
baggedLVintegra   +1y
I have DNA cylinders, can they be rebuilt? If so how and who can do it? I appreciate the help
draggindimes   +1y
post some pics of the cyliners if you can. you may not have to trash the cylinders. i had the same problem a while back. my right front cylinder was leaking down and it was plian as day that it was leakin. if there is a screw cap around the sleeve and the cylinder then it is rebuildable. just call up to where you got the stuff and order a bunch of seals. the smallest pinhole can cause a major leak down
doordraggintaco   +1y
is it wired in a way that when those valves suck the wheel up that the other valves at the other end of the cylinder dump the air to let the cyl go the opposite direction?
baggedLVintegra   +1y
^^^^yes, and i do not see any screw cap around the cylinder
frmlayin   +1y
frmlayin   +1y
^^^^ dont think he's talking about hydro cylinders.
