Air Ride Suspensions \  air zenith compressor what relay
Air Ride Suspensions Q & A
views 626
replies 17
following 13
mike payne   +1y
just needing to know what relay to put on 2 air zenith compressors,,,,please help
sadexcuse4s10   +1y
stinger SR-80 solenoid
it'll hold 80 amps, and make sure you get some stout ass wire that will hold the same amp draw
mike payne   +1y
do i need a relay for each compressor?or can i just run the 2 compressors off of 1.thanks
impulse   +1y
probably be a good plan to get a relay for each.
mike payne   +1y
what if i get a 200 amp stinger relay?
impulse   +1y
get some inline fuses too.
mike payne   +1y
what kind of inline fuses,what amp,,where do i need to put them.
beloved   +1y
im running one air zenith with an 85 amp cont. duty solenoid from napa i got an 85 amp justin case i wanted to run two it sould be enough. also im running #4 wire from the bat. to a block with a 100 amp fuse in line to protect it from a direct short from the block to the solenoid i ran a #8 which is almost a foot plus the ground and a switch to turn the comp on and off manually. havent had any problems yet and it my daily
djn412   +1y
100 amp circuitbreaker.I blew my 80 amp fuse and no probs with the breaker.... I also have two...
rizz0   +1y
wow i don't even think my alt puts out 80 amps damn those suckers draw some current
