Off-topic \  Need Help ASAP! Radio Problems!
Off-topic General Discussions
views 136
replies 6
BankruptRam   +1y
Drove from Dallas to Palm Desert, CA. No major problems till last night we went to a bar in Palm Springs and on the way back to the hotel my Pioneer D1 Nav system shut down. No power to it whatsoever. I have no manuels with me and dont know where anything is. Any Idea which fuse it is? 2000 Ford F250 Diesel.
TuknHard   +1y
check your radio fuse in your main AND backup fuse panels. you will have a main radio fuse and a backup radio fuse, one of those probabily blew. fuse panel should under the drivers dash or in the drivers kick panel, backup should be under the hood.
there are also fuses in the brain (if its separate which I think it is on pioneers) that you can check, but 99% of the time its your main radio fuse.
hope this helps
BankruptRam   +1y
Which one is the radio fuse? I checked them all but I dont have a diagram. Please help. I have no idea how to get to San Diego then to Dallas without it.
TuknHard   +1y
there should be a fuse diagram either on the inside-side of the fuse box cover, if not labeled right under the fuses themselves...if worse comes to worse you might have to pull the fuses out 1 by 1 and check to see if they're blown...
if you have a test light with you you can use that and make it a little easier, but you might have to pull them out 1 at a time and check them.
BankruptRam   +1y
I think its one of the block fuses that you cant check with a test light cuz i already tested every one i can. Nothing has a diagram. The dash pannel for the truck is in my shop in Dallas and im in Cali.
TuknHard   +1y
ok radio fuses are usually 15 amp or less standard 2 prong fuses...
did you check the backup fuse under the hood? did you check the fuses on the brain itself?
see if you can check the accessory fuse too I forgot about that one...
BankruptRam   +1y
I cant figure it out.
