looking for some power!!!
rhynosis
i know about the calmini stuff, but i was looking more for a tubo, and a supercharger, something that will really give me a power increase, if any one has any ideas of were i can get something like this, or any ideas all together, im all ears, and i want to keep the 2.3, unless some one wants to sell a efi 302.
mmrcustoms's avatar
mmrcustoms
put a 350 in it with a 5 speed
Minty Fresh Maz's avatar
Minty Fresh Maz
You should get the Fast Freds Pedal Conversion with the Barney Boost
rhynosis
yeah i thought about a 350, other than motor mounts, a radiator and a wiring harness with computer what else would i need, and how hard a swap is it? i know i would need to build a tranny mount, am i missing aayhting, is a fast freds conversion a reall thing?
jetts
check the junkyards and sometimes if your lucky you can get a nice one for cheap running
isuzu impulse, its the same 2.3 motor as in the pickup, but its got a better head and its a 2.3t
rhynosis
anyone else have any ideas?
SS
sesame street
if you wanna keep the 2.3 the cal-mini stuff will give you a big upgrade from stock. put straight pipe from the header to the a hi-performance muffler (flowmaster) & a turn down before the rear end. 8mm spark plug wires & upgrade the plugs. you can add an electronic fuel pump, but, with those can be a b!tch to get your carb tuned right.
if you go w/ a 350 upgrade your best bet would be to go to the local drag strip & talk to the folx there. you'll need a shortened driveshaft & new rear end. the 1st gen s-10 driveshaft will work. they are the same as those year model camaro.
mmrcustoms's avatar
mmrcustoms
what reanr end for better highway speeds i have 20s and the rmps are high as hell i also have a amigo trans
Related Discussions in Isuzu
