General Discussion \  Bolt Pattern on chevy duallys
General Discussion
views 2008
replies 10
following 7
krewzlo   +1y
Does anyone know if the bolt pattern for a 98 c3500 is the same as the new 01 body style for the wheels? Thanks John
lockone   +1y
They are the same lug pattern 8x6.5 the only difference may be the rear hub the newer style truck depending on if it has drums or disc it will have a larger hub bore. Drums=fit Disc=different hub bore
I am pretty sure that this is right, my book shows all 8 lug patterns are the same except 99+ Ford and some hub bores are different.
Hope that helps.....L8R
bdydrped   +1y
^ correct on the hub bore issue.
pig rig   +1y
now thats settled lets whore this thrad
bdydrped   +1y
LMGDAO
paul42   +1y
I'll go check the back brakes....
dragnasty   +1y
Who cares about the hub bore?......that is, as long as you know someone who can mill.....
low95xlt   +1y
sell lock sell away LOL
lockone   +1y
If they wont fit due to the hub I will sell you some spacers for them....
paul42   +1y
My brakes are drum. Krewz can you measure the hub bore on the rims just to make sure.
