blown engine, what are options
karkid avatar
karkid
i blew my 4.3 in my 2wd 94 ck1500, what are my engine replacement options? i really have no idea, but i'd like to be able to tow my wakeboarding boat.
Low_SST avatar
Low_SST
get a 350 for a few hundred
SCOOTER avatar
SCOOTER
any small block chevy will most likely fit in there or you could get another 4.3 plus if you get a fuel injected v8 you can use the stock harness cause the computer is the same one for a 4.3 and a v8.
SlamedGMC avatar
SlamedGMC
Edited: 8/3/2006 4:12:58 PM by SlamedGMC
Here is ya one...and cheap too lolhttp://store.summitracing.com/egnsearch.asp?N=700+4294925232+4294908216+4294918831+115+318622&autoview=sku&Ns=P%5FProductLine%7C0505 hp for your vehicle!
These GM Performance Parts 2006 Corvette Z06 LS7 engine assemblies will deliver huge power. The 7.0L (427 cu. in.) engines produce a whopping 505 hp at 6,300 rpm, and 470 ft.-lbs. of torque at 4,800 rpm. They feature cylinder heads with CNC-machined intake and exhaust ports and combustion chambers, creating ports with surgical accuracy for maximum power production. In addition, the intake valves and connecting rods are made of high-strength lightweight titanium.
Additional features include:
* 11.0:1 compression ratio* Cast aluminum 6-bolt main engine block* Forged steel 4.000 in. stroke crankshaft* 70cc combustion chambers* 2.02 in. intake valves and 1.61 in. exhaust valves* Hydraulic roller camshaft with 0.591 in. lift at the valve $13,499.95
ShakinPlates avatar
ShakinPlates
I PAID $2K FOR MY MOTOR FROM MY LOCAL DEALERSHIP. I SPENT ANOTHER 1500 ON HOSES, RADIATOR, AND OTHER GOODIES.
