metal epoxy adhesive used on trucks tv
burntrubber@gmail.com's avatar
unfadeble's avatar
unfadeble
does any one know what kind of metal epoxy adhesive they used to patch the 1/4 panel on ths s10 on trucks today? i know GM glues there tailgate relocator patch panles but does that stuff really work?
down2earthdawg's avatar
down2earthdawg
if you have automotive paint supply shop near you ask about the 3m metal epoxy I saw a demo at the finish masters store and its awsome and creates a strong bond best thing is you dont have to worry bout grinding teh welds down or heat worpage.
gsrb20b's avatar
gsrb20b
it is called speed grip the only bad thing about it is you can not have any filler or putty directly on top of it, it will cause bubbles. you can put fiberglass over it and then bondo or putty. duramix is also another name brand.
91 drggn dime's avatar
91 drggn dime
another shitty thing about those epoxy's is, if you paint your truck a light color or your stock color is light, it will show a yellow outline of where your panel is, over time. happened to more then 1 of my friends trucks, all done by very reputable shops
2480's avatar
2480
SEM also makes it
weld bond adhesive-39537
this stuff is crazy strong too. i've done body work right over it and had no problems with it yet
scrapinranger
3m makes some also it is called automix 8115
bgp1mpin
ive always been able to see the ring around the panel that got glued in but other than that that stuff works ok i used the sem stuff but i wont use it again because of that
