Kyrasis6
lol, that actually doesn't say much considering you can get an electric pump for a carb system or an injected setup.
Typically your pumps rated for carbs will put out 10 psi max. After that you would need to look at flow to see if it would support the consumption of your engine although most should unless your running something crazy.
For something fuel injected you will need something that will put out atleast 40-45 psi or more.
