any input on how to keep 22re cool
X
1989dangeroustoy
my motor keeps warming up,seems like its getting a little hto any sugestions...lower temp thermostat?,cold air intake?,electric fan?....what do you guys think i should do
2lowtoy
thermostat 1st then if still over heating radiator pluged
thesource161
i was told that yotas come with a cover that basically goes from the core support over the top of the radiator. like a seal kind of. they told me it was easier for the air to escape from there so to cover it up and then the air would be forced into the radiator.
onehightoyota's avatar
onehightoyota
have u got anything done to the engine? head work? pullin a trailer a bunch? are u leakin fluid? is your radiator full? the only time i EVER had a problem is when the bearing in the front of my water pump went out. when the engine was runnin the water pump would leak fluid onto the engine and the heat from the block would evaporate the fluid and i'd run out of fluid every now and then, when the fluid got low, the engine would overheat. i have taken my thermostat out during the summer. its a waste in the summer.. a thermostat keeps yuour engine too hot in the summer. i drive mine everyday pullin a big trailer, i've got a triple core radiator and i take my thermostat out in the summer. 22RE's are bad about the engine bein too hot and detonating so takin out the thermostat actually helped my gas mileage and kept my engine temps in the cool all the time. im me or grop me an email. i got plenty more tips on 22RE's if the temp still stays up after u change the thermostat.
1989dangeroustoy
the motor is stock other than a rebuild the radiator is full,i took it to a repair shop that i used to work for so there mechanics could double check,and they said its at regular temp,but then the gauge keeps jumping up so im thinking maybe its just the gauge or its really just warming up
