Help with clutch problems?
N
toysrus
Allright, I got a 93 yota today. When the truck is running you can put it in every gear without pressing the clutch in. The truck will not move in any gear and doesn't even try to move. Would those be symptoms of just needing a new clutch or is something else wrong??? Thanks
1989dangeroustoy
thats what was wrong with mine when i got it,the clutch was just burned up to nothing,you can pickup a new clutch kit for like 150,you might need a new flywheel if its burned,it will be a blueish color if it is,mine was burned....those trani's are pretty strong not much can go wrong with them unless someone just totally abused it,but its prolly just the clutch
