Fuel cell on a ranger
bagged92
I am wanting to put a fuel cell on my 95 ranger, but just want to get some thoughts on which one you guys would recommend, i looked at summit at the 16 gallon, but should i buy the one with the sending unit, or the one w/o, im just trying to see if my sotck sending unit will work on the deminsions of the tank, or would it just be better to get the one with the aftermarket sending unit, thanks
Droptout2's avatar
Droptout2
i just used the stock sending unit when i had my 2.9 engine motor. i like the rci cells summit carrys, ive had two now and havent had any problems. if you get a polished one, just keep it cleaned up because its nasty looking all scratched up. also, i really like summit racing (not just because its down my road) but theyre real easy to deal with on parts like that.
Dejavu's avatar
Dejavu
i have one that has a stock sending unti itn it already that i might be looking to get rid of. where are you located?
bagged92
well if your looking to sell it, im interested, i need one ASAP, i drug through mine, im in GA
bagged92
just get me a price with shipping, just pm me and well work from there, my zip is 31220
bodydropped85's avatar
bodydropped85
just get the summit cell w/ sending unit(should work if the ohms are correct) and use an msd pump.
bagged92
I dont know that much about the ohms on the ranger, here is what the website says, will this work, and do i need foam or no, i dont know anything about gas tanks
Brand: Summit
Product Line: Summit Pro Street Fuel Cells
Capacity: 16 gallons
Fuel Cell Color: Black
Fuel Cell Material: Plastic
Foam: Yes
Sending Unit Included: Yes
Sender Ohm Range: 0 ohms empty, 90 ohms full ohms
Length (in): 25.000 in.
Width (in): 17.000 in.
Height (in): 9.000 in.
Outlet Fitting Quantity: Two
Outlet Fitting Size: -8 AN
Return Fitting Size: -6 AN
Sump: Yes
Sump Depth (in): 2 in.
Quantity: Sold individually.
bodydropped85
dont get the plastic one there peices of crap. i mean there good cells i just hate mine lol. get the aluminium 15 gallon one.
bagged92
Well im not plannin on showing it off or anything, itll be under the bed, im just wondering if that one will work, but ill look at the aluminum to, but with those specs, will it work on my ranger, its the 2.3L, thanks for all your help man
bodydropped85
yea itll work. i cant remember the MSD pump number, but its like 90 bux.
