houston i have a problem
liljlowrider avatar
liljlowrider
got my 19's on today...... but wont lay in the back... on the driver side it clears the lip but hits where the fender rolls back in.. on the passenger side i have extra room (just the amount im looking for on the driver side) oh such a bitter sweet day for me!!! what can i do???? got a pan hard bar does it need to be shorter or longer to prevent the extra push to the driver side.. or what else can i do?????????????????????????????????
low95xlt avatar
low95xlt
if your panhard is adj you might want to tighten/loosen a bit to adjust side to side like u thought, we did that ona 6 t 4 lin wit bags that had a adjustible and it moved it the right amount we needed to move to adjust for side to side.
low95xlt avatar
low95xlt
if your panhard is adj you might want to tighten/loosen a bit to adjust side to side like u thought, we did that ona 6 t 4 lincoln continental wit bags that had a adjustible and it moved it the right amount we needed to move to adjust for side to side.
lockone avatar
lockone
depends on what side your panhard is hard mounted to the frame wheter you need to tightd or loosen.
liljlowrider avatar
liljlowrider
ok the bar it bolted close to the end of the link bar (driver side) and then mounts to the other link bar (passenger side) but going in a diagnal direction towards the front of the truck... (if that is as unclear as i think i will take pixs later :LOL:) and my bar is not adjustable so i will have to have a newone made it guess)
baggeddogs avatar
baggeddogs
you can just redo one side's mount to remount it once the rear end is centered... might be easier/faster then redoing the whole thing...
lockone avatar
lockone
^^^^what Baggeddogs said would be the easy way^^^^
liljlowrider avatar
liljlowrider
yea im gunna try that first.... then go from there....
