Page 1 of 3
Foreign Cars (honda, etc) \  oo civic air susp-need help identifying leak
views 365
replies 20
following 9
Nazty   +1y
I have airride suspension & i just bought the car, & the drivers side rear wheel is slowly losing air as i go down the road. The place that did the suspension told me to put soapy water on the lines, i guess, but i have never seen the underneath, nor have i ever looked or dealt with air ride before. Anyone out there know how this should be done???
fatboysS1O   +1y
he's right. just put some soapy water in a squirt bottle and spray all your connections with it. of coarse if u spray a fitting for example and it bubbles up then youve found your leak. but its not that simple. it can be a bitch sometimes finding leaks. id start at the rear wheel and work my way back! if u dont find it some where around the rear wheel like i said spray EVERY connection on the car. if u dont find the leak it could be a valve sticking or a couple of other things but try the soap bubbles first.
shawnswhip   +1y
Russell Crase (fatboysS1O) is right...but if the shop put it in, then they should stand behind their work.
CommonVan   +1y
i have seen the cylenders laek as well
loudciv   +1y
does the car leak down when just sitting?
reason being if it does not leak while sitting, you need check vavles.
Nazty   +1y
i always drop the rear when i get out so i dont know if it leaks just sitting, i have dakota guages so i will check into that tonight.
Nazty   +1y
stupid question...im allowed, so when i get my soapy water ready, would u advise to get the car jacked up on car jacks first, i need advise on that as well. Im not mechanically inclined so safety is first for me!!!
fatboysS1O   +1y
u could air the car up when u go to bed tonight and let it sit up over night then check it in the morning! kinda pinpoint the corner of the car that is leaking. u say its the back left,but that way u can double check and see if u have leaks anywhere else that are real small that u might not otherwise see unless u leave the car aired up for an extended period of time!
Nazty   +1y
any suggestions on getting under it & spraying down in a safe manner???
Nazty   +1y
ok i completely raised my ride & my guages are tellin me that all tires are at 62, except for the one that i am havin probs with, it deflated in a matter of 30 seconds, but i will lift it all night just to make sure there isnt any other leaks anywhere else....
