Mazda Trucks \  now it fuckin shakes
Mazda Trucks Make Specific
views 321
replies 11
following 9
livinlow   +1y
Well about 1 second after i leave work my truck starts shaking and vibrating like crazy untill i hit about 40 kms, or 25 mph, then it's fine, i looked at everything tonight and it looks ok, but who knows i'm not a driveshaft or rearend expert, any ideas as to what this is. rear is bagged with a monoleaf and 3" blocks
dssur   +1y
you need an angle shim with 3 inch blocks and a mono or it is going to shake.
livinlow   +1y
Edited: 8/8/2006 6:23:18 PM by Turbo32
I've had this setup for 2 years now and no problems untill tonight, even when i bagged it it's been fine untill now, does this matter? i'll shim it tonorow and see whats up.
Any idea what degree would be best?
caned96   +1y
maybe the rims are out of balance my yukon would do that from 55 to 60 and smooth out but i had super swampers and after market wheels those weights came off all the time. its a little harder for them to come off of stocks bc they are pounded on not juct put on with adhesve.
dssur   +1y
carrier bearing or one piece. If it has a carrier I would bet money on it.
If its a one piece you have a broken u joint, usually the trans side goes first.
livinlow   +1y
it's a 2 peice with a carrier, i was thinking that myself.
bdroppeddak   +1y
the u-joint at the carrier bearing would be a checking point also.
SSM-Webmaster   +1y
hey cris call me!
NorthwestRides   +1y
If it is the carrier bearing, or U-joints, that's cake work and shouldn't be hard to fix bro. I went through this same problem with my S-10 but I had a double-cardinal driveline on it and had to custom fab a new driveline on it. What a bitch! Good luck!
-JO
NWR
bdroppeddak   +1y
Edited: 8/8/2006 7:26:08 PM by bdroppeddak
im at real work they hate when i use the phones for personal use! i dont get off til midnight, i'll give you a ring around 8'ish tomorrow mornin.
