00 civic thinkin about nos.......what to do???
N
Nazty
i have a 00 civic with a k&n air intake & i am curious to know if you can put nos on it with it just being a stock engine....will it kill my engine? >eventually???? Or what would be sum good suggestions as what to modify first so the engine could support the abuse....Im new so be tender
Low_SST's avatar
Low_SST
watch 2f2f and then decide.
crux131's avatar
crux131
Yes and no on the killing the engine part. Depends entirely on the set up and tuning. I have seen people run wet and dry systems for a long time with minimal problems. This was with propper fuel added to the mix though.
I have also seen someone blow a stock motor the first time they used a 65 hp dry kit....I think it was a zex kit. They of course didn't upgrade the fuel pump, and he got trigger happy and went for a test run before the pump was swapped. Fuel system couldn't keep up the nitrouse and boom.....toasted d-16.
I would definitely research the decision before slapping anything together.
N
Nazty
So ok i gather that i would need to swap the fuel pump....any other suggestions???? I see alot of good things about the ZEX set-up....seems to be the choice.....
CM
c mau
jsut upgrade ur fuel system like a mo-fo..
STUD1Y's avatar
STUD1Y
buy a new car.
