Dodge Trucks \  HELP!! Where have u guys relocated fuse box to??
Dodge Trucks Make Specific
views 129
replies 9
following 7
onebadkota   +1y
Well i got in there and have #rd, cut, and stripped all 68 wires to the fuse box...but now im having a hard time positioning it anywhere...im going forward with it...but not sure if i should try to get it on the frame, put it vertically against the front close to the radiator, or put it flat but up close to the headlight......Any suggestions????
bdroppeddak   +1y
if you are just layin frame you can make a bracket to hold it, and leave it in the stock spot.
fatheadjames   +1y
I put mine under the wiper cowl to clean up under the hood.
cantlooswit22s   +1y
i did the same thing ^^^^^ but i also gota fullsize.but i still did it.lol,looks much better now.
booga   +1y
I PUT MINE BEHIND THE DASH?
ramsey   +1y
just finished mine and it is behind the headlight.
RobbyDizzleonDubs   +1y
Anyone have pictures? My 20's rub aginst my wire harness that comes out of the firewall. My fuses box has been relocated about 9 - 10" and is mounted on the frame near the power steering pump. I was thinking about pulling the whole harness through the firewall and putting it under the dash and locating the fuse box under the steering colum behind the panel.
fatheadjames   +1y
I just ziptied the harness up and it clears fine.
ramsey   +1y
If yours is legnthened that far you could put it where i did, behind the headlight, then if you have custom fenderwells, the wires would run right over the top of it. If not it fits nicely under the fender lip and zipties out of the way.
I just moved my fusebox behind the headlight, and up off the frame. Good idea Ramsey!!!
