Full Size Truckin General \  pinion angle ??????
pinion angle ??????
views 144
replies 4
thekidd   +1y
does the 1-3 degree pinion angle apply to an irs setup ?? can you just run the drive shaft straight to the rearend ?? mike covered the straight axle setup but not the irs setup a couple of months back in mini truckin...
bdroppeddak   +1y
irs is just like the straight axle, but easier because theres no travel in the rear end.
thekidd   +1y
so you still have to have the 1-3 degree on the drive shaft from trans paraell to rearend paraell
bodydropped85   +1y
yup other wise youll have hella drive line vibration and kill the U joints.
thekidd   +1y
thanks for your reply. that's what i needed to know
