fuel cells in 88+ fs
I
ixenn
Anybody know whats the best fuel cell for these trucks and what kind of fuel pump i will need, and also what do i need to do to get the gauge to work? thanks for the help
redcrew's avatar
redcrew
get a 20 gallon or so i use a holle electric fule pump with about 16 psi or so youll need more psi for a vortec becase tbi's take less to get the gauge to work hook up your gauge wire to the sending unit
BUILTON24S
Mallory 6040fi pump with an inline regulator and hi pressure fuel filter...i spent around 500 bux for everything.good luck
redcrew's avatar
redcrew
its not that hard just use the wires off your factory tank and extend them to were ever you want them my pump was only like $150
I
ixenn
what about the 95 its the hybrid tbi/vortec bs is the pump external and will i have to buy new hoses and such, can anybody recommend a model and maybe have a site i can order from?
redcrew's avatar
redcrew
a 95 is tbi vortecs didnt come out in fulsizes till 96 i got mine out of jegs its the same pump holley uses on the fi kit i had hoses made
redcrew's avatar
redcrew
the factory pump is internal the one i used is external
I
ixenn
well it says vortec on the engine so i dono lol
redcrew's avatar
redcrew
its probly early 96 you can still do it the same way youll just need more psi from the pump
I
ixenn
well i know its not efi because it only has two injectors , its a weird motor if you ask me. also i don't know if i matters buts its the 4.3 v6
