Toyota Trucks \  engine idle when brake depressed- help!
Toyota Trucks Make Specific
views 305
replies 10
following 8
dropduallie88   +1y
I have a 93 toyota, it runs great but when the engine is warm and I have my foot on the brake the idle drops and raises continually. I hope this makes sense, anybody have any suggestions?
dropduallie88   +1y
My other toyota was like this also, I was hoping it was a common problem. anybody?
time1   +1y
It has to do with vacum, check for leaks in all the vacum lines.
cookiemonster13   +1y
vacuum booster is leaking
dropduallie88   +1y
I checked for vacuum leaks and didnt find any. It only happens when truck is warm, thats why its throwing me off, how can I be sure it is the booster? if I were to replace booster is there a smaller booster from a different vehicle?
bad andy   +1y
Sounds like the booster. you can replace it with a brake booster off of an 84-88 toyota automatic truck. Those boosters are smaller than the manual transmission ones.
dropduallie88   +1y
thanks I'll try that then.
cdk1978   +1y
When you depress the brake pedal if you hear air blowing then it is for sure your vacuum brake booster
2lowtoy   +1y
I had the same problem on my 89 4wd and the TPS was bad changed it and fixed all my problems
low downin   +1y
this may sound really odd my toyota did that while low on coolant. yes coolant when i had a leaky water pump i would notice that when i depressed the brake at a stoplight the rpm would race or nearly die erraticly. hope this is any help
