73 thru 87 bolt on 4 link
dirtybreadbox@hotmail.com's avatar
EKSESSIV CONTROL's avatar
EKSESSIV CONTROL
F.B.I has a bolt on four link for these trucks ... has any one here used one , how well are they made has any one used this on a suburban and will it work. I talked with the guy at F.B.I. and he did not know just trying to save myself some work . but if not could you guys give me some mesurements on the four links for this truck gettin ready to lay it out and want to be prepaired for the worst
Grant Kustoms's avatar
Grant Kustoms
what about the KP link?
EKSESSIV CONTROL
havent tryed that just starting to get info .. I will look into it
ostncoln's avatar
ostncoln
Edited: 8/24/2006 1:54:01 PM by ostncoln
i had one on my truck. it worked pretty good. you would have to modify the front frame brackets to get it to lay anything bigger than a 20" about 28-29" tall maybe
sinwagon
I haven't had any feed back on the difference between the C-10 and Suburban frame. I don't believe that it'll be a direct bolt in, though. Haven't had ANY complaints regarding strength issues! It's a pretty simple install.
burntburb's avatar
burntburb
well the frames are PRETTy much the same ecept that the leaf springs on the burb's are longer so any direct bolton with no ajustment will not work UNLESS the manufacute says so.... Be Carefull with your Purchase
EKSESSIV CONTROL
how much longer and they are (supposed) to be adjustable
