Painting Eninges
VB02431@YAHOO.COM's avatar
Painting Eninges
VB0243's avatar
VB0243
o.k So how is it done ? i have seen alot of glossy paint but how do they do it without peeling from the heat ?
no1lowr's avatar
no1lowr
hi temp primer is what im using\
bdroppeddak's avatar
bdroppeddak
dont crank it.
AiredOut's avatar
AiredOut
I just use K36 as a primer, and regular old base clear for the paint. Lasts a long time. The engine in our shop truck has been done 10 years and run 75,XXX miles and still looks fine.
TwistedMinis's avatar
TwistedMinis
I use VHT paint. Its nice, and its resistant to oil, coolant, whatever. However I've never paint matched an engine, just went by factory colors.
armandlatouffe
The easiest way is to use a good primer, and to use high heat paint from a spray can..
If you want to paint it base/clear, make sure you wash the engine properly (I like to use Castrol Super Clean), put like 4 coats of primer, 2-3 coats of base, and 3-4 coats of clear.. ..oh yeah and use a good high-heat primer..
leftcoast66
I'm with seth, VHT is awesome and they got lots of color choices. I just ran flat black on my 350 and gloss black on the 390 for my dad's car, never done any other crazy colors tho.
2lowtoy
same here
