Nissan Hardbody Steering Wheel Question
U
U
uncivlized1
I have a 97 Nissan Hardbody and I am looking to swap out to a better looking steering wheel. Can anyone tell me what hub I will need. I am wondering if I can buy an assembly for a 240sx, maxima, altima, etc. and it be the same. I fanyone knows if it is the same as any of these please let me know what year and model so i can be sure to order the right thing.
BK2LIFE's avatar
BK2LIFE
goto autozone or checker or stylin concepts.com, or apc.com, or google.com you should be able to find your answer
fatheadjames's avatar
fatheadjames
You might be able to get one for an older one before it had an airbag and should fit.
97hrdbdy's avatar
97hrdbdy
I have a 97 with a grant wheel
I used the kit listed for the older hardbodies (around 92-93).
Only problem with mine is i had to remove the cancelling assembly for the turn signals (i have to turn off the turn signals manually now after making a turn)
dragginbottom
I HAVE A CUSTOM MADE ALUMINUM ADAPTER THAT CAME OFF OF MY BUDDIES 97' HB! HIT ME UP FOR PICS!
shavedmax
a stock nissan should just bolt up. theyre usually universal in that respect. cant say the same for the airbag though
sidriver15's avatar
sidriver15
I would buy a leccarra hub and a billet steering wheel!!! Why do you want a maxima,altima,240 etc .....I would go all the way with a billet wheel..just my opnion..
downplz
Pretty sure he is asking if a hub addaptor off of one of those cars would work...
And like stated before the addaptor off of an earlier model before the airbag was introduced will work.
kustomcreationz
^^^^ that should work just fine. The part # for a Grant adapter (hub) is: 5560-1
Hope that helps a bit.
