Isuzu \  BRACKET HELP
BRACKET HELP
Isuzu Make Specific
views 259
replies 3
untamedprez   +1y
OK DOES ANYONE HAVE OR COULD THEY GET A EXACT TRACE OUT OF A BRACKET TO MOUNT MY YORK 210 IN PLACE OF MY SMOGG PUMP. I CANT SEEM TO FIND ANYWHERE THAT MAKES THEM SO I GUESS IM GONNA USE A PLASMA CUTTER AND GRINDER TO MAKE ME ONE. ANY HELP WHAT SO EVER WOULD BE GRAETLY APPRECIATED
DragDatZu   +1y
if i remember ill take a pic of the one i made tommorow.........just tak a pece of steel tubing the size of the bolt your gonna use on the bottom of the smog bracket and weld it to a peice of flat bar...then dril holes in the flat bar and bolt it to the bottom of the york.....this is the bottom pivot point. Then make a upper belt tensionin bracket by drillin a hole in a peice of flat bar then burn a slot in the flat bar. bolt the hole to the top hole in the smog pump braket.then take a peice of flat bar and ben a 90 degree angle in it .....dril holes on on side to bolt to the top of the york and on on th other side to put a bolt through. this bolt wil go through the 90 and the slotted belt tensioning bracket deally.and your all mounted up ....this will make way more sense when i post a pic
blazed22s   +1y
Edited: 10/9/2006 4:40:26 PM by Blazed22s
i plan on puttin a york there shortly. so a pic would be nice, i think i was going to do it a different way, but im not sure yet.
mmrcustoms   +1y
hey i want pixs to and maby if u pull it apaty and trace it all and then mail me the temps. and measurments that would be bad as* and or just alot of pics
