s10 Control Arm Bushings
phil@twistedimages.com's avatar
TwistedPhil's avatar
TwistedPhil
We have a set of byc S10 control arms over here that are missing the bushings. I know they're different from the stock bushings with those metal sleeves on them- does anyone have a source/ part #s/ any information I could use to make this a complete set again? Hate to see them rust away in the shop... Thanks in advance!
-Phil at FBI
TwistedPhil
Anybody? I may have found some part #s for Daystar bushings... does anyone have a supplier of choice for them?
bdroppeddak's avatar
bdroppeddak
Edited: 8/30/2006 8:49:45 PM by bdroppeddak
whats the part #?
W
waylowwhitey
try fullsize chevy shackle bushings, they might work..... the ones from 4wheelparts. They should have a minor OD of 1.5", and they are Daystar bushings. You can order them direct from Daystar. At least, you could a couple years ago. I still have that pn# laying around, I used those bushings for a while. If I remember right, it was MO2262, or maybe those were the ones for 1.6 minor OD. Let me look around, I will Pm you if I find the info
bdroppeddak
if you want a lot of them you can order through daystar....
TwistedPhil
I've had a few people mention Daystar, but I'm not finding them on a Google search. Any contact info out there? Thanks again for any help!
-Phil
W
waylowwhitey
Edited: 8/31/2006 8:42:11 AM by waylowwhitey
I am still searching for the info, I have a big file folder around here somewhere with all their info and all the part numbers of their bushings. Another good thing is that they will custom make any size bushing you want, at least they used to. I believe Daystarweb.com was their address, you can probably go from there. here is their contact number:(800) 595-7659 try that for starters.
TwistedPhil
Wow! Thanks a lot, guys!
W
waylowwhitey
Edited: 8/31/2006 9:40:22 AM by waylowwhitey
Are they PN# M02124 ? I have a few of those laying around, if you only need a few.... wait, are they uppers or lowers? I have a full set of bushings for the uppers as well, contact suspension restorations. That is where the upper bushings originally came from.
s10
last post by baha +1y
