Body work and Paint \  Por 15
Por 15
Body work and Paint Q & A
views 364
replies 16
following 14
shavenotbagged   +1y
So i undercoated my frame with Por 15 right well it came out good BUT i read the can said wear glovs when iw as all done the shit ate though a litle bit i have little spots on my hands anyone knpow what i can use to get the stuff off?
armandlatouffe   +1y
The only things I could disolve POR15 on my hands with were either thinner, gun wash or gaz.. ..that stuff is really hard to remove..
TwistedMinis   +1y
Basically you have to wait for it to wear off. It will take about two to four weeks.
radar   +1y
They make a thinner for POR 15. That what I used to thin it down to spray it.
slammed88cutlass   +1y
It kinda hurts but i've found the only good way to remove it is to literally scratch it off along with a little skin. if you wash your hands a bunch with some coarse automtive style hand cleaner that will speed up the process also. if you get a substantial amount on yourself consider it a 2-3 week tatoo cause it is not coming off.
dragn4door   +1y
Time takes it off. I can't even look at a can of that stuff without getting it on me.
armandlatouffe   +1y
You should try with a grinder and a wire brush, but I don't garantee the result.. hehe
bodydropped85   +1y
lol if i get some on my skin, i wash it off w/ thinner, RIGHT then or its on tehre for a while. also you dont have to thin it down to spray it, but youcan.
twankydeuce   +1y
last time I got it on my skin I took aome wet sand and a tooth brush and rubbed it into my skin and it came off. It wasnt the most pleasant thing but it worked
Jance Customs   +1y
Post some pictures of what you painted. I'm going to use some and want to see the end results. Thanks!
