Pa Pa Dragger
BclassBD, I have a fullsize Chevy truck with a manual trans. and they suck to bleed . Here is what works on these trucks. Install the complete system on your truck, fill the master cylinder and bleed it at the slave cylinder bleeder screw while someone pumps the peddle. After you do this work the plunger on the slave at the clutch by hand. Push it all the way in and let it return and do this 7 or 8 times and you will feel it build preasure. This way you work the air out the top and out the master cylinder. Works like a charm. Hope this works on your Mazda.
