blazer tank?
blue_jeep69@yahoo.ca's avatar
blazer tank?
blackice's avatar
blackice
i am concidering switching to a blazer tank in my 95 C1500. will the blazer pump be enough for my 305 tbi, or will i need to upgrade it, or make my stock pump fit?
blackice's avatar
blackice
anyone?
altitudeadjustments
I put a blazer tank in my suburban and I just put the suburban factory fuel pump in the blazer tank just to make sure.
Camshaft
depends if the fuel pump is from a 4.3 tbi blazer or not. if its from a multiport fuel injected blazer the fuel pump will supply to much fuel pressure. TBI pumps are all basically the same, they all operate in the 9 - 13 psi range, you just might need to change the electrical connectors.
blackice's avatar
blackice
thanks. i figured knowing GM , they would most likely be very similer pumps, but i wasn't sure.
