Body work and Paint \  whats a good filler that will bond to ABS
Body work and Paint Q & A
views 787
replies 12
following 6
Low_SST   +1y
Im looking for a filler i can use on my dash bezel on my ram to smooth out some work ive done on it. is Fiber Tech my best bet for this?
Low_SST   +1y
NE1
klrbzcrtoys   +1y
duraglass and rage will bond if you ruff up the plastic but i dont know what exactly you are trying to do so i dont know if its your best bet
Low_SST   +1y
ill post a pic up today of what mi going for.
Low_SST   +1y
i think i may just end up with this...
Fiber Tech
Low_SST   +1y
Fiber Tech
Severed701   +1y
unless you need alot of fill and a bunch of strength for what your using it for..i wouldnt use that shit...its so damn hard to sand...you can get plastic repair putty that sands nice..is flexible, and sticks good to plastic
Low_SST   +1y
here is a rough sketch of what im goin towards. this piece of hdf is glued in place with a 2 part epoxy glue that is made for bonding stuff to plastic, the only area i need to really fill is the very center of this piece to match the contour of the bezel itself. it will eventyally support a double din tv headunit and a few gauges so i want it strong as possible.
Severed701   +1y
you can use fibertech for its strength..but just try and get on it before it gets too dry..and i would use a roloc grinder to shape it to about where u want it and then use something easier to sand over it to get it finished like metal glaze
98dakota20   +1y
you should put some progress pics up. (when you make some progress)
