Chevy/GMC Trucks \  00 S-10 Brake Problems Please help
views 118
replies 1
following 2
JPerry   +1y
Edited: 9/6/2006 3:06:49 PM by JPerry
Alright so about two days ago I was driving home on the freeway when I hit some bumps while I braked, and something weird happened then after everytime I braked It felt like the pedal was moving its hard to describe. It still brakes fine, but it almost feels as if there is air in the brake lines, or something, I dont know but I dont like it. And I really dont want the brakes to fail on me. Has anyone had this problem with their s-10's, and does anyone know how to fix it? I think I will go get new brake pads and bleed the brakes. (eventhough I dont think it has anything to do with the pads but who the hell knows?)
Thanks ~JP
SuperchargedS10   +1y
i havent ever had that particular problem but it sounds like maybe you do have some air in the lines but if you have air in the abs system thats a different story its going to take a while to bleed that out best thing to do is to go top off the fluid and start the truck while you bleed the brakes out it will get really hard to but you want to get it past hard and make it fel cushy agian i had to do it on a buddies blaser it took me the better part of an hour also makes sure you bleed all four corners theres no telling what line the air went through to get in the abs only other option is the dealership or a shop that has a drivability tester(which means expensive)
