so ive got nitrogen right now, with the bottle going to a 5 or maybe 6 gallon tank then to the valves. is there any way to bypass using the tank? or could I down size the tank size? maybe to 2 or 3 gallons? also do i need a check valve going form the nitrogen to the tank to prevent air leaking out of the regulator after the tank is closed?thanks in advance
I run my nitrogen bottle without a tank or check valve. I like the setup ok. I think I would rather have a tank inline. I believe the suspension would be a little faster to lift.
usually regulators have a check valve in them, i would only run one from the compressor to the tank only so you don't have 400 psi going to the compressor, if you have a tank the suspension will be faster than if you don't :fon:
