Air Ride Suspensions \  panhard bar
panhard bar
Air Ride Suspensions Q & A
views 340
replies 7
following 7
BaggedC10   +1y
i have a cantilever 2-link i need to know if the bar should be level and parallel to the axle at ride height? Since when i lift it all the way up the axle will be moving forward alot should i have heim joints on each end of the bar?
bdroppeddak   +1y
make it as long as possible and have it parallel to the ground at ride height, and use a good quality heim with cone washers.
BaggedC10   +1y
just one heim joint? or one at each end of the bar?..
slammeddime   +1y
One at each end.
balcar   +1y
if you dont' have one on each end, it will bind, esp cause its a 2 link.
Lexpusher96   +1y
I just bought the Panhard bar and parallel four link from Suicide Doors. The panhard came with one polyurethane joint and then one heim joint. Hmmm...
DooredFord   +1y
i used to have a panhard shifted the truck too much all the way down went with watts link.
olskoolpup   +1y
thats b/c with the parallel 4-link the axle wont move fore and aft very much. regardless with a 2link the axle will move quite a bit.
