baggin a 79 silverado
22draggin01
Edited: 9/11/2006 12:24:07 AM by 22draggin01
does anyone have any advice or help for gettin a 79 silverado to lay?
riceeter85's avatar
riceeter85
i bagged my 85 chevy in the front i did air ride techs tubuler upper and lower a arms with 2600 lb bags and 2inch drop spindals and it pankakes the crossmember in the back i cut the frame off at the cab and biuld a new rear frame out of 2x4 square stock.
91 drggn dime's avatar
91 drggn dime
i would use mcgoughy's spindles, sd's cup/plate setup, slam re7 bags. then you need to z the front frame 2-3" i forget exactly how much, it depends on the size of wheels you wanna run. You can also do a 2.5" engine crossmember drop, but its easier to Z the frame. that'sthe only way to 'lay' the front out, b/c your LCA's are lower then your frame. you will drag through them
in the rear, I would go with a wishbone 3 link with bags onthe lower bars. you could go parallel 4 with a panhard bar and sleeve bags over the axle, but i'd take the first choice.. i'd prob go re8's in the rear of that sucker. you also need a 6" notch to lay on up to a 22.
fatboysS1O's avatar
fatboysS1O
not being a prick but youd prolly get more responses it the chevy/gmc thread!
22draggin01
acctually i have no idea how this ended up in the dodge forum
balcar's avatar
balcar
Closet dodge owner....
