72' datsun 620 drive shaft
WU
Watch Ur Toez
Alright, carrier bearings are getting exspensive. I need a solution for my drive shaft. I had the idea of taking a hard body shaft and have it sectioned down. Or a ext. S-10. I need the slip, joint, 2 piece. Any idea's or pic's would be awesome. Thanks.
TwistedMinis's avatar
TwistedMinis
Bring in your driveshaft to a driveshaft shop. Take a measurement from the tranny output, the the rearend and have them make you a one piece shaft. If thats what you're looking for.
time1's avatar
time1
They got 2 piece driveshafts in those little trucks? WOW
Do what Seth said, and have one made.
WU
Watch Ur Toez
Ya, it has a factory 2 piece
TwistedPhil's avatar
TwistedPhil
If you have access to a wrecking yard, the 69 and earlier trucks (the ones with the old pushrod 1300 motor) have a one-piece driveshaft that works great!! The only downside is that you'll need to notch the back of your cab if you lay out at all- minor inconvenience, though!
Good luck either way you go!
-Phil at FBI
