INFO ON BAGGING REAR OF 67' CADI
tuckinutz@yahoo.com 's avatar
H8MENOW's avatar
H8MENOW
I WAS HOPING SOME OF YOU GUYS CAN HELP ME BY GIVING ME THE INFO ON BAGGING THE REAR OF A 67' CADI OR PICTURES WILL BE HELPFUL ASWELL
TEEBAGGINNN's avatar
TEEBAGGINNN
Mount the bottom of the bag to the top of the factory link bars. On the top get universal upper bag brackets.
tofnlows10's avatar
tofnlows10
didnt no it was that easy.....good to know..
thesource161
check out this page under current projects. they have a pics on NO1LOWR's 69 getting bagged. it only has one of the rear end though. http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=43537773
doordraggintaco
NOT SURE ABOUT A 68 BUT ON MY 69,THE BAG HAS TO BE ON TOP OF THE AXLE.2500 PD BAGS IN BACK AND 2600 IN FRONT.2 INCH CUP FOR TOP AND NO CUP ON BOTTOM.S/D S10 CUPS IN FRONT TOP AND BOTTOM.
bagged300mondubs
yeah, pics would be great i just bought a 70
shvd64cdy's avatar
shvd64cdy
Markus..............geez bro.........what? now you can't call Kurt? Seem to remember us rolling around in his 67........hmmm.....
nah bro, mount the bag to the link bar by the rear axle (closer to the axle will give you less lift, too close to the wheel, and it will probobly give you some problems trying to lay out) so find the happy medium there and go for it. drill a hole through the link and mount the bottom of the bag, use a chevy full size or most any generic cup (less that 2" tall, 1" ideal) and you'll be set.
bodydrpdsdime
the bags dont go on the link bars that is on the x-frame cars 64-down. On 65-up the bags will go over the axle where the springs are at and i personally like to use a sleeve bag in the rear as they get more lift and ride nice. You can use the stock shock mounts and buy a shorter shock.
grip's avatar
grip
That is correct except the stock shock will work unless you notch it.If you don't notch it on a 235-75-15 it won't lay.215-75-15 will.Also the motor and tranny will drag if you don't move them up.If you move them up the drive shaft won't clear.
