a good shaved door handle kit?
lester622 avatar
lester622
i guess ima shave the door handles on my dually, so wats a good kit that wont give me to many problems cause ive had alot of trouble with shaved door handle kits in the past but i bought cheap ones so i guess u get wat u pay for.............. is the SPAL kits anygood?
baha avatar
A Benifit of Spal is they come with a boot that covers the moving part of the solenoid so water can't get in, get corrosion and cause it to seize. I've only used auto loc and had trouble when I mounted them vertical because with out the boot, I had some corrosion issues but then I remounted them horizontal and had no problems at all very dependable Check out our vendors man they can set you up
bdydrped avatar
bdydrped
spal has a kickass 7 channel kit for a decent price(from many different vendersrather than directly from spal)
what i ended up doing was buying the 7channel kit with 2 solenoids and found another "kit" with 2 solenoids and relays and used that on mine ended up being about 40 bucks cheaper then buyin the 4 door kit with the same brain part. and if i ever want to add anything else just gotta grab a couple relays and hook it to what ever i want.
lester622 avatar
lester622
so u have 2 different remotes for your doors are there all wired into one remote?
balcar avatar
balcar
mine is wired into the alarm, so I can pop my doors on command without having all sorts of crap in my pocket. and I use the autoloc ones, they work the best from what I found. The inside is stainless (or plated) so they don't rust, just got to the inside and change out the e-clip to a stainless one and lube it up, and yer good for years..
lester622 avatar
lester622
phil, all i can say is ...................... ur my HERO
balcar avatar
balcar
lester622 avatar
lester622
yummmm.......yummmmmm, hahaha
balcar avatar
balcar
Here is the starter shaving kit. everything you need.
lester622 avatar
lester622
well congratulations phil on gettin ur first shavin kit ..... ::::clapping::::
