Mystery puddle of water at front passenger side floor....
F
fuelrags
Hey guys!, after a period of rain, I get a puddle of water under the floor mat around the front passengers feet area. I sat in the truck one day while my kid poored water all over the cab area and nothing! Has this happened to you?
balcar's avatar
balcar
mine only leaks on the drivers side, so I can't help.
lester622
probably the heater core, haha nvm i didnt see the "after it rained" part, the windshield could be leaking i know on my silverado when it rains hard water comes in threw a crack in the windshield.
Post was last edited on Sep 17, 2006 03:18. Edited 1 time.
burntup
it could also be the gasket around the door. I had a blazer that did that.
balcar's avatar
balcar
taste the water, is it water or maybee something else? Is it yellow? maybee the kids are hiding something......
pig rig's avatar
pig rig
well after a long thought period and the lack of info I've came to the conclusion that you have a leak that you should address
dragginbody
I have had the same problem, the water comes form where the blower motor is for the ac. It gets in from under the hood on the passenger side by the hood hinge, there is a little black box on the firewall that is where air comes in when you have the the a/c set to outside air, make sure the seal is good on that and there is no cracks in it. Also take it out and seal the back and then put it back on, while its out reach your hand into the hole and clean out anythings thats in there, trust me you'll be suprised, i found leaves and a feather all kinds of debris that gets blowin in there.
bdydrped's avatar
bdydrped
might pull the cowl panel off and make sure there isnt a bunch of leaves/debris in the drain part for that... if it is backed up and full of crap it will fill up and leak to the inside of th ecab.
