LEAKS
untamedprez@yahoo.com's avatar
LEAKS
untamedprez's avatar
untamedprez
OK I BAGGED MY 93 AND NOW IM HAVIN A BAD PROBLUM WITH TRANY FLUID LEAKIN AND REAR DIFF FLUID LEAKIN BUT WHEN I WELDED EVERYTHING THE PINION ANGLE WAS DEAD ON ANY SUGESESTIONS.ITS LEAKIN FROM THE OUT PUT SHAFT SEAL OF THE TRANNYAND AROUND THE FRONT BOLTS IF YOU UNDERSTAND WHAT IM SAYN
gotsparks's avatar
gotsparks
i just had the same type of problem. is your driveshaft yolk makin a wierd rattling noise? thats what mine did and it started leaking real bad and it ended up i had to buy a new tranny, clutch, and driveshaft... hopefully u wont have to buy all that stuff. gooluck tho
-jordan
shortrodeo
How much slip do you have left on the driveline when you move your truck through its hights? Almost sounds like your driveline is stabing into your tranny.
untamedprez
not much movement at all i watched it after we did it there was almost no shaft movement at all i think the seals just need to replaced cause its a 93 those things are still the original
untamedprez
oh and i have an automatic and no no noise of any kind
think changin the seals might help?
farmer joe's avatar
farmer joe
yeah, change the seals and it should stop leakin. i need to change the tranny seal on my truck. its slung fluid all ove the bottom of the truck. messy...
untamedprez
yea thats the exact problum i am havin and its all over my back glass and tailgate
Related Discussions in Isuzu
