Chevy/GMC Trucks \  ??? on nbs chev. two link
views 284
replies 10
following 8
Rollnlow00   +1y
i am building my radius arms out of 2x2 square tubeing and using my factory front leaf spring brakets. my question is for anybody that has this same setup or knows about it is where did you find and what size bushings for the front of the bars. much appreciated any help.
KNDAlow   +1y
if youre using your factory leaf spring brackets you should just order some factory bushings and find some round tubing that the bushing will fit into. i sure suicide doors makes ends with bushings that you can buy and weld on as well.
Rollnlow00   +1y
ive tried that and it seems that no auto parts store in town can get them the only place i havent checked is gm but im scared to and the only bushings i found on suicide the bolt hole is too small mine is 5/8 if im not mistaken the closest i found was like 3/8 maybe but thank you for the sugestion
03on22s   +1y
Suicide doors also has new front brackets that weld on the side of the frame in place of your stock hangers. They're not that much like 20-30 bucks.
jsondrops   +1y
bushings on leaf springs are not serviced from gm
1 LoWfUKn RaM   +1y
cut up ur leafspring ends thats what pretty much every one does
thesource161   +1y
^^that was my thought.
waylowwhitey   +1y
Try 4wheelparts, 88-98 GM shackle bushings, and some 2" OD, 1.5" ID dom tubing.
Rollnlow00   +1y
thank all of you very much for your input. it will help me out a ton.
SOINSANE   +1y
You can get leaf spring bushings from any springshop in your area.around$30-40 bucks for the 1/2 ton chevys
