Nissan Trucks \  brake problems
brake problems
Nissan Trucks Make Specific
views 155
replies 4
following 5
hardbody88   +1y
wassup guys,something is seriously wrong with my front end.when i was braking my front right tire started to jump! i dont know how else to explain it. when i start driving my wheel on the right side starts shaking but when i get it up to about 20mph it stops,but when i try to brake then i hear a noise that sounds like something snapping back into place if any one out there has had this problem please help me out.mahalo from hardbody88
Minitucking   +1y
Check to make sure your strut rods are tight to begin with, thats the rod that goes from the front end the lower control arm to keep it from moving forward or backward, then make sure everything is tight and your bushings are all good and no slop in them
LOBLZR   +1y
my old s10 did that exact same thing once, one of the caliper bolts had sheared and was letting the caliper rotate partially, good luck
McClarys   +1y
agree..... check that first..... that is if you still have them, which you do need ..
deflatd   +1y
yea my truck rattles at slow speeds eso on my driveway and all ever since ibagged it. and we ditched radius arms. and sometimes when i break its jumpy and pulls. im adding something in now. donw worry. you think its a radius arm problem that caused that stuff tho?
