Rodeo dash swap
Rodeo dash swap
DragDatZu
im plannin on puttin a slightly newer rodeo dash in my 94 pup.....pretty much plug and play rite? im talkin bout from a rodeo thats the same body style but newer
dragn168's avatar
dragn168
if you have a tach its prety much the same dash if you want somethin really nice snag one out of a honda passport same truck as a rodeo but the dash is more rounded and is centered more around the driver and i think they had a leather option but thats neither here nor there
sicpupidaho's avatar
sicpupidaho
They are not a plug in and play they need some work to make it fit right.
DragDatZu
like?
sicpupidaho
you will need the brace that goes in the back that the steering wheel bolts to.You we need to take some of the brackets off that go up to the defrost vents(that black piece).you can use your gauge cluster if you trim some of it.the e brake needs removed or you can cut the lower panel.thats all i can think of right now i will add more when i remember.
Related Discussions in Isuzu
