DUAL PORT BAGS?
nvr2lotaco@yahoo.com's avatar
DUAL PORT BAGS?
nvr2lotaco's avatar
nvr2lotaco
I have always been curious to how they work...do you hook up a valve to each port? Or what? How are they supposed to be hooked up? Thanks in advance..
Rigo's avatar
Rigo
well you can do numerous combination and get different effects....
nvr2lotaco's avatar
nvr2lotaco
Well i was gonna run them on my truck...and any info on hookin them up would be great
TwistedPhil's avatar
TwistedPhil
Unless you want to run 16 valves and go ballistic, most people run one port for lift and one for dump. The response time with this setup is faster than T'ing the dump off, so it makes a slight difference.
From there, you COULD run a separate lift valve to each port, which could get you hopping like crazy!
Other options include using the extra port for your gauge sending unit/ line, plumbing a "slow" set of valves into the extra port so you have the option of not slamming to the pavement... There are a lot of ways you can use them, but it's most commonly used to increase speed.
-Phil at FBI
fatboysS1O's avatar
fatboysS1O
yeah what Phil said. ive got some dual port re7s up front on mine. 1 port for fill & 1 port for dump. when i had bags over axle in the rear i had dual ports back there too,but since moving them just got single ports now.
s10
last post by baha +1y
