Fuel Filter...
Fuel Filter...
groundedwatts
hey guys...where exactly is the fuel filter located on 89-94 Yota 2WDs??...ill probably find it before i get a response, but hit it up anyways...thanks all
time1's avatar
time1
its on the passenger side of the block under the intake
groundedwatts
thanks bro
groundedwatts
that looks more like the Oil Filter to me....any pictures....im trying to change out my FUEL FILTER...any help is muchly appreciated...thanks
time1's avatar
time1
Edited: 10/4/2006 3:04:50 PM by TiMe_1
Cmon dude, I know WTF im talkin about. Its there, look harder. Its bolted to the block.
I am assuming that this truck is fuel injected.
I know the difference between an oil filter and a fuel filter.
:SLAP:
groundedwatts
lol...after further investigation (looking harder)...i see it!
sorry bro...i wasnt saying it wasnt there...just said i didnt see it.
i see its bolted to the block...could you help point me where to start in changing it.
It looks like a PITA to get to!
thanks bro
time1's avatar
time1
uhhh first relieve the pressure in the line. there is a certain procedure for it but i usually just open the line on the fuel rail to relieve it. Do it slow so gas doesnt spary every where!!! (put a rag over it when you loosen it)
There are 2 gas lines on the filter, one in, and one out. Undo those first then take out the 3 or 4 bolts that hold the bracket to the block. Then there will be a couple bolts that hold the filter to the bracket.
I usually went thru the wheel well area with the tire off and a long extension on a ratchet.
Good luck!
groundedwatts
thanks again bro....big help. I got it done!
time1's avatar
time1
