rear end work
rear end work
burntup avatar
burntup
looking for a little help in Texas. I need to change the bearing in the rear end of my truck. I think it is the pinion bearings. so does anyone have any experience in this field?
maz89 avatar
maz89
pull the axles, remove the chunk (gears), remove the nut from the pinion gear, remove pinion gear, replace pinion sill, and reverse steps..... follow that?
burntup avatar
burntup
is it really that easy? I thought you had to shim the rearend and get the backlash right
jcampbell1180 avatar
jcampbell1180
uh...
pig rig avatar
pig rig
if the gears squill they are to tight if they howl they are to loose
burntup avatar
burntup
i checked the gear oil for metal and there was nothing, you can move the yoke a little and i was told it was the bearings going out. not sure.
guilty by design avatar
guilty by design
Setting pinion depth is crutial. Unless you have the tools and know how to read/use them have somone else do it.
1fastlx avatar
1fastlx
If the gears have not been worn from the bearing being lose then you can replace the bearing using the shims that were installed from the factory just make sure to get a new crucsh sleeve and nut for the pinion. It is a pretty straight forward job but it would help to have someone who has some experience when you are ready to crush the sleeve and check the gear mesh.
liljlowrider avatar
liljlowrider
i havent ever work on one either steven but if you need help tearing it up let me know!:lol:
maz89 avatar
maz89
^ that's the spirit!
