How to C-Notch my frame?
chaddiesel@hotmail.com's avatar
chaddiesel's avatar
chaddiesel
What should I use to cut the frame of my 1999 F-150? I don't want to remove my bed or my gas tank. Think I could do it with a saws-all?
I
iceman9669
use a sawsall or a torch, plasma cutter!!! jut be careful and make sure you have the exact spot on both sides and then make sure to reinforce it all
slammedxonair's avatar
slammedxonair
its gona be alot easier if u take the bed off it only takes a couple minutes. also your gona need a welder unless you have a bolt in notch
Iownissan's avatar
Iownissan
i think you'd actually save time by taking the bed off
Iownissan's avatar
Iownissan
NorthwestRides's avatar
NorthwestRides
The bed is like 4 bolts generally and then the gas neck. I couldn't imagine how much of a bitch it would be to notch your frame with the bed on That'd be irritating and too cramped for me, unless you're like 4'8".
-JONWR
slammedxonair
its its a pain in the ass to notch a suv wihout cuttin the floor out or takig the body off
layingnutz
YOU'D BE DUMB TO NOT TAKE THE BED OFF. MINES A 99 IT ONLY TAKES 15 MIN TO GET IT OFF.
Forever Draggin's avatar
Forever Draggin
and 2 guys, i would def undo the six bolts and the gas neck and its off, 15 mins top. that will cut down ur notchin time down by atleast an hour i bet, and ull be able to make sure everything is exactly square and parrelel
