bagging 95 blazer
dooredford@gmail.com's avatar
bagging 95 blazer
DooredFord's avatar
DooredFord
my friend just got a 95 blazer the fornt is bagged already but pretty hack the vlaves are mounted on top of the intake manifold of all places lol, anyways to get it on the frame what is he going to need and he got a set of 18's with a 13mm offset is this going to work? i told him to get 20's but he didnt want to.
xinsertnamex's avatar
xinsertnamex
depending how big the tires are remove fenderwells and all the shits thats on em, maybe tub the firewall a hair, move the wiring harness up, might have to mod the heat a/c or just get rid of it all together, modify the stock arms or get tube arms ull need some drop spinldes most likely too
the rear depending if its a 4dr get a 2dr gas tank and move it to the rear or make the stock one work with some tubing, cut out the floor, weld in notches, notch the gas tank x-member, RUN A 4 LINK!!!, cut out the stock wheel wells maybe tub them into the doors not quite sure kinda doubt it on a 18 tho
as far as 2dr not sure never did one but probably the same as above minus the gas tank shit and tubing into the door
if i think of anything else ill post it up good luck
DooredFord's avatar
DooredFord
its a 2 door he got the control arms from SD.com already has spindles but he dropped 650 bucks on the control arms! im sure someone coulda made 'em cheaper.
