Air Ride Suspensions \  Mini-truck driveshaft shortening
Air Ride Suspensions Q & A
views 257
replies 6
Cesure   +1y
Hey I'v got a 98 S-10 bagged with the 5link rear end. I have some horrible feeling coming through the shifter it seems like the driveshaft might be pushing into the trans.Could this be the problem?Thanks
BAGD RANGER   +1y
dont shorten the driveshaft --- its a problem with the link install not the driveshaft !!!
Cesure   +1y
So does that mean that the pumpkin is too close to the trans. as in the axel is sitting to far forward
BAGD RANGER   +1y
i could just mean they didnt sit the pinion angle right and maybe they have the rear end a bit forward --- in that case you will hear some ruff grinding --
cheeks Sunset SD   +1y
if it is a suicide 5-link then you may have to shorten I am going to guess your truck is a 2000 or newer reg. cab? mine had to be shortened. no matter what you do.go on the s-10 cult forum and look it up.
Cesure   +1y
Yah it is the SD 5link its a 1998 reg cab. So I do need to get it cut eh? shitty well i guess thats better then if it was install wrong thanks
Cesure   +1y
I should check it the pinion tho
