Chevy/GMC Trucks \  another wheel question PLEASE HELP!!!!!!!
views 392
replies 13
following 8
dirkbelt   +1y
im gettin the eagle alloys 025 wheels and the only offset they offer is +14 and +40 i know that the 14 wont work but will the +40 fit bagged????
Rambo   +1y
easiest way to know is read up on offsets and then measure for yourself
dirkbelt   +1y
its 6.875 backspacing
dirkbelt   +1y
my bad its 6.785
OGDOUGHBOY   +1y
if the +40 tucks to much bro you can laways get a 1/4 inch spacer to push it out a little but. i think you will be fine though, make sure the bore size will work on your truck in the +40. sounds to me that is made for cars with the same bolt pattern but might have a different bore size
Dooredon22s   +1y
i would lean towards the +40 offset because i have a +15 on mine. but I had to narrow the rearend 3" and section the control arms. before i did the tire hit the bed sides. hope that helps a little
dirkbelt   +1y
heck yea i just dont want 2 mess up this time,im gettin a good deal this guy that lives down the street can get the wheels tires lugnuts mounted and ballanced for $1500
dirkbelt   +1y
bump
redcrew   +1y
I have boss wheels on my 88 and they barely clear. 22-9.5 not sure on the off set. I almost got the eagle 025s there made by same people if I remeber they had the same offset.
dirkbelt   +1y
u dont know what offset they are???
