whats wore out???
liljlowrider@yahoo.com's avatar
whats wore out???
liljlowrider's avatar
liljlowrider
i just remembered to ask this after driving my truck for the first time in a couple of months. when i am coming to a stop i sometimes get a wheel shake but only sometimes. it seems its getting worse.. when i put the 22,s on it i replace the upper ball joints and rotor and brake. it will happen even when im not brake just slowing down. a couple of time i have hit a bump in the road going around a corner and it will start shaking , if i apply the brake and slow down it will stop.. if anyone can tell me what i should replace to fix this problem let me know.. i know that its not out of balance shake, or wrapped rotor shake.... what is it guys??????????????
krewzlo's avatar
krewzlo
Did you run over another mexican?
Tie rod end?
Pitman Arm?
wheel bearings loose, worn out?
Maybe one of those bent 22's from TWAT?
J/k
Have you tried greasing the all the zerk fittings on the front end? Try it and see if it goes away or gets better. It may tighten something up just enough with the grease to make it go away temporarily and then you can narrow it down to those parts.
That is all I can think of right now.
liljlowrider
oh yea new wheel bearing also... but i didnt grease everything else.. i will do that tomorrow and see if it fixes anything
low95xlt
lube her up and try it again i would say pitman or tie rods
maz89
there goes lilj talkin about "lube" again....
onefasthoagie
there goes the start of "whorin" ^^^ any how try wheel bearing, they seem to loosen up pretty often on mine. seems like every 4 months i have to tighten one of them.
liljlowrider
yea thats gunna start the whoring damn it!!!!
im gunna lube it up good today at the shop and see what happens.. and also i know its not a bend wheels cause i was havin this issue with the 19,s just seems to be worse with the bigger wheels
and yea LUBE scares me
huskerdually
jack up the front and grab the wheel and try to move it and see where there is play it should be pretty simple to find.
maz89
hey, what can I say.... I'm slutty....
burntup
mine did that, it was the control arm bushings
