mazda front bags
W
mazda front bags
F
FrameLayinTaco
ok i just got my cab body drop done and at max lift i'm like 3/4 of an inch or so from clearing my rims...is need body running a 7 inch slam on the front of a mazda i have airlift 2500s on the front of it now and i noticed after doing sum research that my bags max diameter is 6.8" and a 7 inch slams is 7" wouldn't that .2" be nothing to swap out....thank
TwistedPhil's avatar
TwistedPhil
We had a customer run 7" Slam bags that he got from a friend up front on his Mazda a couple years ago, but I don't think he make enough clearance for steering, as he was back the next week for some 6" models! It might be possible, but a 6" Slam will get you more lift than your AirLifts without the clearance issues.
-Phil at FBI
dssur's avatar
dssur
do you have drop spindles? if you do the upper arm is hitting the spindle before you max out the bag. Happened to me and a few others.
A 6 inch slam will get higher than smokey in deebo's pigeon coop though.
F
FrameLayinTaco
could that still be the problem even if i have different (non-stock) upper control arms?
dssur's avatar
dssur
dunno, I guess look and see. Or take a picture.
sinwagon
Yeah, let's see some pics. It's tough to fit a 6" bag in the front of a Mazda with out it rubbing. I don't think a 7" will work for you, dude.
twiStedatsun's avatar
twiStedatsun
Check the placement of your upper bag mount...If the bag is fully compressed when your truck is layed out then your stuck but if not move the bracket down. Well not stuck but this won't apply.
